2BBL to 4BBL upgrade
mrsnicks
7:09 AM
cameron, nc
So I'm going to upgrade my 318 2bbl to a 4bbl edelbrock intake and carb.
Question: Do I have to change the automatic transmission kick down linkage?
2nd Question: Anyone have a source for the kickdown linkage springs?
Don't know about the linkage and springs...but if you just use the car for friendly cruising it's probably better to just keep the 2-port... :)
Just about anytime you make an intake/carb change that deviates from stock, you will also need to modify the kick down linkage.
Linkage is easy. You can extend it.
Throttle cable bracket is a bit harder, but it can be modded/bent/added to.
