TrackPack
I noticed something on several bore stroke charts. The 67/68 383 engines are listed with a 3.375 stroke, and in 69 it increased to 3.380. Is this right, or are some of these charts screwed up?
.005 thousandth?I noticed something on several bore stroke charts. The 67/68 383 engines are listed with a 3.375 stroke, and in 69 it increased to 3.380. Is this right, or are some of these charts screwed up?
I just noticed that the 361 was also listed as 3.375 too. That was dropped in what...66 or 67?
I call that "rounding". If you look at FSM you notice the "common" dimensions are some sort of rounding.
Much easier to quote two decimal points. The FSM have the .000 numbers, we just need to pay attention to them. All in fun for discussion.Easier to hold tolerance when machining for .xx instead of .***, probably just a running engineering change to reduce costs and scrap.
Sure, but it doesn't really affect anything.Unfortunately (or maybe fortunately) these differences in stroke were submitted to the NHRA for blueprint specifications in class racing.
Right. Just follow the applicable NHRA rules and specs, and maximize or minimize to your benefit any tolerances they allow.Rules allow for adding .015 stroke to the crank, so need to use the right specs.
