george glover
any idea what 308 head cc volume is they are from89 truck ,i am trying to buy pistons to up compression tks
there on carIt's pretty easy to set it up and measure them.
simply question turned into a treasure trove of info i don't need tks
You are welcome lol.simply question turned into a treasure trove of info i don't need tks
tks thats the answer i was looking for my heads were done small cut they have to be around 68 or even more tksMagnum 308's 68.4cc - 72.4cc
LA 308's 57cc, 60cc, 68cc
they had small cut done so iam guessing around 68cc tksYou are welcome lol.
More folks here messing with the big blocks, IDB. A lot of the same peeps are over at FABO where they mess with a lot more small blocks. Of course, many of the same folks are here.... May be worth your while to go ask over at FABO and see if someone has measured them??? I don't want to guess, cuz that's not helpful at all. You should be aware tho, the reason you got "measure them" is because they vary, and yours may have been cut already for all we know.
HTH, Lefty71
