WTB 360 Magnum Pistons
HEMIB
12:27 PM
Australia
Anyone know where i can get Magnum 360 standard stroke + .020 -5 cc pistons floating pin
you would think so but everyone you call no stock including Summit & Jegs,Campbell
You may want to elaborate on your piston specs, not being "Magnum" specific..
* Dish or flattop?
* 5cc is usually indicated as +5cc for valve notches.
* Forged, hypereutectic, cast?
* + .030" might be easier to find.
* I believe original Magnum pistons are narrower in the pin area for the corresponding narrower OEM rods at that end also. But most aftermarket pistons can use Magnum or LA rods. Double-check.
Dish -5 cc, .030,Forged ,.984 floating pin, i beam rod ,3.58 stroke
