moparmusclecars
I have a 489 chunk and rear end complete out of a 1970 6 pack Super Bee (v coded car) auto car. I am assuming 323 gears, but i will need to confirm. Car was wrecked with 9k miles on it. Rear axle tube on one side is bent slightly. I also have a rear end in my 69 Super Bee that has a good housing, but is a 741. Can i use the 741 housing and switch all the guts out of the '70 Super Bee rear end? I believe the housings are the same, correct? Is this something i can do myself, or would i need special tools to accomplish this task? Pull the 3rd member, axles, brakes etc and clean up the housing i will use, installing new axle bearings, seals, etc. I noticed the 741 unit did not have the brake drums with fins, so i am assuming it is no the original rear for my 69 Bee. What more is there to doing this. Since the chunk should all be good still, its merely swapping out parts for the most part, correct? TY for any advice.
