4 speed steel crank how deep is the hole for the trans to slide into it
moparjohnny
10:57 PM
ga
not sure how deep it should be?. thanks
It only needs to be deep enough to slide it in.Too deep of a hole is a waste. Also, to make sure it fits just right, it's not a bad idea to lube the hole up and slide the shaft in an out many times. However, keep in mind that if it's an old hole, the fit may be sloppy which is just no good at all.
What he said!
Gosh,,, I can't help but think you're talking about something entirely different......HMM?
