66 convert
1972 400 purple shaft cam (not sure which one ), edelbrock performer intake,new 625 cfm street demon carb,1970 440 heads,mopar performance distributer with orange box,edelbrock performer fuel pump.At idle the the motor has 6 to 7 hg vacuum.I just put lighter metering rod springs in which did help.I also have a factory hemi stall speed in trans.Car will idle from cold for 30 minutes.Put it in gear everything is fine runs good.Drive the car for 30 minutes it runs good until you get to a stop light and the idle will drop off and stall.It will get worse as the engine bay heats up (but motor doesn't over heat)Help I am open for suggestions very frustrated.Thanks 66 convert
