426 wedge pistons
Rolling Thunder
9:41 PM
Trenton, IL
Looking for standard bore 10.5 compression pistons; new or good used. Would consider up to a couple sizes overbore if thats all I can find.
Picked up a beautiful 64 street wedge standard bore block I'd like to build.
426 wedge pistons are hard to find you may be better off getting custom pistons as the factory pistons are hard to find if the block is sonic checked you may go to .070 over will get it to 4.32 440 stock bore. egghe has stock piston but the pins are very heavy and you will have to balance the crank.look for stage two max wedge pistons about 11 TO 1
Thanks...figured that may be the route I have to go. I know these are obsolete engines but bought this block cheap and is going to fit my boys 330 nicely. Is standard bore and going to have sonic tested so fingers crossed that it has a lot of extra meat.
