jdsgtx
Hey it’s jdsgtx here! Sounds like you need to start toRetime it from the beginning and check everything440 71 Plymouth satellite when I crank key in car it crank but not firing. If I jump it on the relay it fires, backfires thru exhaust immediately and dies. I put distributor in 10 degrees before top dead center. I have advanced and retarded the timing and same thing. I had it running before but the more I started it the hard to start. It would puff white smoke out the top of carb and spit. I took carb out and cleaned it. But I wanted to check everything bc a buddy checked the timing and it was 30 btdc but might have been misread. I took valve covers off and everything was moving looked good. What should I check lol? Can’t keep running a sec or two…so I’m unable to check timing .
