SOLD 440 lifters, cam, timing set, pushrods and valve springs
Terry's 65
4:20 AM
California
Feedback: 1 / 0 / 0
The onlytime any of these were run was a dyno pull. I decided to go with a hydraulicroller cam.
Asking 275.00+ S&H
The cam &lifter specs are:
Brand:Edelbrock
Manufacturer's Part Number:7194
Part Type:Camshaft and Lifter Kits
Product Line:Edelbrock Performer RPM Camand Lifter Kits
Summit Racing Part Number:EDL-7194
UPC:085347071944
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,500-6,500
Intake Duration at 050 inch Lift:238
Exhaust Duration at 050 inch Lift:246
Duration at 050 inch Lift:238 int./246 exh.
Advertised Intake Duration:300
Advertised Exhaust Duration:308
Advertised Duration:300 int./308 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Valve Lift with Factory Rocker Arm Ratio:0.480 int./0.495exh.
Lobe Separation (degrees):110
Camshaft Gear Attachment:1-bolt
Computer-Controlled Compatible:No
Lifters Included:Yes
Lifter Style:Hydraulic flat tappet
Valve Springs Included:No
Retainers Included:No
Locks Included:No
Valve Stem Seals Included:No
Timing Chain and Gears Included:No
Assembly Lubricant Included:Yes
Pushrods Included:No
Rocker Arms Included:No
Gaskets Included:No
Valve Springs Required:Yes
Quantity:Sold as a kit.
Notes:Single-bolt camshaft. Although theadvertised RPM range for these camshafts is 1,500 to 6,500 rpm, for bestperformance we recommend a minimum 3,000 rpm stall torque converter be used inapplications with automatic transmissions.
Their powerbandis from 1,500 to 6,500 rpm, and they maintain 10 to 12 in. of vacuum at idle.
The Timing set:
Brand:Edelbrock
Manufacturer's Part Number:7804
Part Type:Timing Chain and Gear Sets
Product Line:EdelbrockPerformer-Link True Roller Timing Chain Sets
Summit Racing Part Number:EDL-7804
UPC:085347078042
Timing Chain Style:Double roller
Maximum Advance/Retard at Camshaft:2 degree
Maximum Advance/Retard at Crankshaft:4 degree
Thrust Bearing Included:No
Offset Bushings Included:No
Gaskets Included:No
Bolts/Studs Included:No
Cam Sprocket Material:Iron
Crank Sprocket Material:Billet steel
Quantity:Sold as a set.
Notes:Single-bolt cam gear.
The valve spring are off RPM heads:
Brand:Edelbrock
Manufacturer's Part Number:60929
Part Type:CylinderHeads
Product Line:Edelbrock Performer RPM CylinderHeads
Summit Racing Part Number:EDL-60929
UPC:085347609291
Cylinder Head Style:Assembled
Cylinder Head Material:Aluminum
Cylinder Head Finish:Natural
Combustion Chamber Volume (cc):84
CNC-Machined Combustion Chamber:No
Intake Runner Volume (cc):210cc
Exhaust Runner Volume (cc):70cc
CNC-Machined Intake Runner:No
CNC-Machined Exhaust Runner:No
Combustion Chamber Style:Closed chamber
Intake Port Location:Standard
Exhaust Port Shape:Rectangular
Exhaust Port Location:Standard
Spark Plug Style:Angle
Intake Valves Included:Yes
Intake Valve Diameter (in):2.140 in.
Exhaust Valves Included:Yes
Exhaust Valve Diameter (in):1.810 in.
Valve Springs Included:Yes
Maximum Valve Lift (in):0.600 in.
Outside Diameter of Outer Spring (in):1.550 in.
Damper Spring Included:Yes
Number of Springs Per Valve:Single
Retainers Included:Yes
Retainer Material:Steel
Locks Included:Yes
Lock Style:7 degree
Valve Stem Seals Included:Yes
Valve Stem Seal Style:Positive stop
Rocker Arm Studs Included:No
Rocker Arm Nuts Included:No
Guideplates Included:No
Valve Cover Mounting Style:Perimeter bolt
Accessory Bolt Holes Drilled:Yes
Intake Valve Angle:15
Valve Guides Included:Yes
Valve Guide Material:Manganese bronze
Valve Seats Machined:Yes
Valve Seat Machine Style:3-angle
Valve Seat Material:Ductile iron
Steam Holes Drilled:No
Oiling Style:Through head
Machined for O-Ring:No
Heat Crossover:No
