SOLD 440 Rb based 505" Stroker
Green72
4:21 PM
Feedback: 1 / 0 / 0
I have a 505 stroker engine that I would like to sell. I built this engine in 2019 and have put about 3000 miles on it. It runs perfect and has a ton of power. Rotating assembly was purchased from Hughes Engines. He also did all the machine work. The block was sourced from a 1976 motor home. Trick Flow 240 heads. I would also include the MSD Atomic Throttle body injection; I have been really impressed with this system. Cam is a solid flat tappet; specs will be in a pic. Hughes rockers with B3 racing geometry correction. 10:1 compression runs great on 91. I was meticulous during this build, all clearances, ring gaps, valve clearance and anything else was checked and rechecked. I will post a link to my build thread. Come hear it run and check anything you want. The rear main does drip a couple drips after driving. Headers are included. $10,000 OBO Lisbon Iowa 52253​
My First build
Hughes Engines
