5 th Avenue disc brakes.
jag_mopar
2:14 PM
Now in East Orlando FL.
Can anyone give me the application that these will fit on for conversion from drum? Will the Master and booster work as well?
thanks
Booster won't fit in a 66 but will in a 73/74.
M/C will need an adaptor if the car had a 4 bolt, but if you are putting it in a 73/74 along with the booster it should work.
All other parts will work on both, most is same as 73/74.
I have this setup on my 66, including the combo valve. Had to make my own lines, but was able to rebend 5th Ave line that goes across firewall.
They will fit all b-bodies 62 and up. A-bodies 76 and down (72 and down needs 73 - 76 upper control arms). All E bodies.
I know the booster will not work on 70 and down b-bodies or the e- bodies.
