BeastlyBirdie
I currently have a cast iron 6 pack intake, Dec 69 date. How much weight would I save if I went with a new aluminum one? Any benefits of the cast vs alum? Thanks.
weight savings is about 50 pounds.if you go with a new aluminum manifold it will have better flow charicteristics then the old cast iron.you will prob gain a bit of hp,but not a ton.
Actually the weight difference is about 31 LB.
but it's a really heavy 31 lbs ... when you are lifting it off the engine in the car ... let me tell you what.
I guess I'm a sissy. I used the engine hoist on my friend's six pack when we replaced the intake gaskets.
I've been there more than once and you can't do it from the front either.!!
