FOR SALE 62 Dart 4 Door Hardtop Parts Car
matthon
11:20 AM
New York
Feedback: 5 / 0 / 0
Not much will be left, frame rails, k-frame, inner fenders, trunk lid, rear end, trans, what's left of the engine, seats, doors, glass. Front bumper is tweaked but frame rail looks straight and true.
Could have more left on it.
Also have another complete 318 poly 2 barrel that I just pulled, that turns, if wanted.
This car needs to be gone by July 1st per my local town (dept. of annoying neighbors.)
$600 obo, I'm in 12302, and I can bring it to you within a reasonable distance for an additional fee.
I still need to remove for myself the heater, front fender, bolt on inner fender pieces, torsion bar support, rear floor under the seat, cowl, rear quarters, trunk extensions, rear trunk support, and some of the remaining trunk floor.
Whether I get to all that by 7/1 remains to be seen, either way it needs to be gone by then so I figured I'd throw this out there.
No ppwk, no keys, no shipping.
20190609_175148.jpg 20190609_175201.jpg 20190609_175214.jpg 20190609_175314.jpg 20190609_175301.jpg 20190609_175356.jpg 20190609_175402.jpg 20190609_175426.jpg 20190609_175733.jpg 20190609_175855.jpg
Need to scrap it by Sunday.
Anyone interested in excellent frame rails, inner fenders, or 318 poly engines?
Any chance the door hinge springs any good ? Front and rear doors are the same. I bought repops that are weak and have no spring. Need 2.
I'll check tomorrow, I think they're weak though, doors creak and need to be pushed closed, same as my 2 door.
Shouldn't the doors shut when pushed, is it because only the top hinge has a spring, or because the springs are shot, or both?
Usually the roller rusts and don't roll no mo.The hinge and roller rub so that makes the doors hard to close.Very common when not lubed for 50 years. The springs should be ok to re-use. Most of the time they just break.
I know they are a small part and I understand if you don't want to bother with taking the hinge off and removing the spring.I'm ok either way.Thanks.
Matthon, take a look at this passenger side b-pillar metal reinforcement plate.
I'll pull the hinges this weekend but I think the springs are all loose, just hanging there, maybe the little rollers are gone.
B pillar parts and glass pics.
I wish I had somewhere to put this car or an easy/quick way to cut out the good stuff that is left.
The front and rear seats were definitely replaced, original material is a copper/pattern, blue covers over them.
I needed the rear seat bottom frame, but the top and front seat are still there.
Couldn't get hinges off, front and rear are definitely different.
Front are same as 2 door hinges, below are the springs off of them.
Cut a section of frame out and it stayed together.
