Looking for some of the rubber seals that go between the lights and body on the 62 Plymouth B bodies.
I have had the taillight buckets off my 62, but it was a loooonng time ago!The seals are “U” channeled rubber that fit around the base of the lights not gaskets. If I have to Jerry rig them I wouldn’t use gasket material.
Ill check with him. I believe the bottom edge of the 62 bezel is around 1/8” think - not more than 3/16”.Joe Suchy carries a "U" shaped rubber gasket that fits the 1964 Polara large bezel to body. It will be more material than you need, but might be the right contour. Joe would likely send you a small sample to confirm shape.
Try Restoration Specialties & Supply, Inc. They have a web site They have u channel and other items for our cars.Ill check with him. I believe the bottom edge of the 62 bezel is around 1/8” think - not more than 3/16”.
