63 door interchange ?
Small Block
4:18 AM
West Plains, Mo.
hey guys and gals, I've got a 63 2 dr hardtop I've pulled in the shop and started finding out what I need to make things a bit easier. A drivers side door would save some work and I think other model doors will interchange. For those if you that know which other model doors will work? I can repair the one on the car if I strike out on finding another. Which ones? Thanks
A 64 or 65 hardtop bare door will fit. The vent window frame is different (slant is different because of the windshield angle) and I believe the door latch opening at the back of the door is a different shape . 64 and 65 use the same style latch, but 63 was different. Changing the vent window frame is not a big deal since you have one on your current door.
Sounds right as I think the cowling design was changed appreciably btw 63 and 64.
