fmahannah
1963 Dodge Polara Max Wedge Tribute
- 5:29 AM
- Sep 25, 2014
- Dahlonega, North Georgia
Need some electical help here. My 63 Polara 500 with 413 was fine when I first bought it, but one day on the way home from a show the volt meter (aftermarket) and the dash ammeter were bouncing wildly low and high. Next day car would not start, so it must not have been charging.
Bought a Standard VR101 voltage regulator (this is what was in it), swapped it in, jumped the car and everything was fine again for a couple weeks.
Took it to town the other day and noticed low steady voltage around 12, only came up a wee bit at highway speed. Got to the store and would not start. Luckily I carry a jump pack with me all the time.
Just changed out the voltage regulator again with another VR101, started up and was charging close to 14 volts and seemed fine. Bent over the engine compartment and thought I smelled something hot, sure enough there was smoke coming out of the new voltage regulator!!!
Shut everything down and disconnected the battery, but now I am not sure what could be going on. Car is very clean, engine wiring all clean and tight.
Battery is almost new. Alternator appears to be standard type and new as well.
Does anyone here have ideas as to what could cause a new voltage regulator to start smoking? I was very careful not to ground either of the terminals. There is a green wire that connects to the field terminal and two wires on a double spade that connect to the other side. Pretty hard to screw up LOL.
Woody
I found this in the instructions that came with the regulator. Could this be what I am seeing and is it safe to run the car until it stops smoking? I don't want to burn anything up.
"New electro-mechanical regulators may smoke for the first 30 minutes of operation. The resistors under the regulator are varnished to keep windings in place during manufacture. When the regulator is first turned on the varnish burns off occasionally giving off smoke."
Woody
