I will need a set also for my '63. Keep me posted if you find some, although I will probably go with a trunk mounted battery. Could definitely use the ground though...
We have the 63-64 and 65 positive cables available for the V8 applications. Also available are the negative cables for 63 to 65 B-Body applications. Two different lengths are available, so would need to know which you would require. These cables feature the correct gauge wire, loom material and ends to duplicate the originals.
I am still looking for 63 to 66 A-Body samples to have coverage on those applications.
If anyone is interested in viewing them, we will have some available at the Indy Cylinder Head Show on March 3rd through the 5th.
