64 Big Block B Body Radiator
Polara426
9:56 PM
norteast ohio
Anyone with original 64 b body with build sheet tell me the part number for a code 73 radiator
Thanks I have seen that but normaly the last two numbers in the part number match the build sheet my original 426 streetwedge 64 dodge in witch I found the build sheet list a code of 73 for the radiator and my radiator I beleive is original was missing the tag that is soldered on these early B bodies.Most charts show the 35 or 37 for these cars has anyone seen a 2524973 radiator thanks for the help.
What is the build date of your car?
Polara426;I've got a complete 1964 Plymouth parts book in the garage I can check. I'll presume that D/P/C PN's are the same;I'll get those later today and hopefully that will help you.
Polara426;what I've got is a Master Price book,so hopefully this is the part number you need:2445 637. Listed as code VP2 and VD2 with 361,383,and 426 cu. in. engines. Hope this helps!
My build date is 4/30/1964 and I know the parts book shows the 35 and 37 radiators but I wanted to see if anyone who had a build sheet with a 73 code for a radiator knew their original number.anybody?
P-426;I don't know if this info is of any help,but on my track sheet for my car,I've got a "71" in the radiator box. It's a 318 w/AC car originally. I'm presuming that the "73" you seek is a code inclusive to the big-block cars?
Yes Al a big block car your radiator has a center location for the top hose do you still have a part number on your radiator.anybody else with a 73 code on their build sheet?
