john perez
64 Dodge 440, 2 door hardtop, white / red stripe, located 06278. 440 block with Max Wedge Cross Ram intake coupled with Torque Flight 3 speed automatic transmission. Car has Max Wedge exhaust manifolds with racing lake plugs and 3 inch exhaust pipes to the rear Newer restoration, excellent paint and bright works, new interior, tires are in excellent condition, 3.55 sure grip, 8 3/4 rear, Comp Cam, Two Edelbrock 4 barrel carbs, Be Cool Radiator / with electric fan, electronic ignition, all gauges work ( Fuel, Temp, Oil Pressure, Amp, Clock delete ) Remote drivers mirror, seat belts, heater 3 speeds all work, original AM radio which also works, wipers work, all signals lights, dimmers and high and low beams work. Just had tune up all fluids, plugs oil / gas filter changed and carbs tuned. Comes with spare tire, tire cover, jack, base and jack handle. New alternator, voltage regulator, battery and belts replaced. New thermostat, radiator flushed and antifreeze just replaced. Comes with original build sheet,window sticker, original factory divers manual with vin stamped on cover and assorted other dealer brochures and service records . $38,000
