Centerline
Started the clean up of my stock leafs today. The part numbers I found were 2403635 and both springs were identical. These numbers were located on the smallest spring and they were the only ones I could find.
Question: I've heard that some B Bodies used the same part number on both sides. Do the part numbers I found match anyone else's springs? Just not sure if that is the correct part number or if the number is located somewhere else on the springs.
