WTB 64 Plymouth Belvedere Station Wagon gas tank
64maxwedge
5:53 PM
Chesapeake, Va
Looking for 64 Belvedere wagon gas tank. I think others will fit. 62 to 65 B Body Wagon gas tank.
I know later year wagons used part number CR14 tanks made by spectra, but not sure if it’s the same for your 64 wagon.
I have a used, clean tank, no sending unit from a 67 coronet 500, not a wagon, not sure if this would work for you.
40 + shipping
You likely wont find one and if you do its probabaly not in great shape, or dirty. I think there might be a company or two who will make you one new. I have a 1964 Fury Wagon. The gas tank is specific to the wagons.
Its probabaly not what you want to hear but I would pay to have one custome made in stainless steel. The original ones are basically impossible to find without corrosion on inside which will eventually eat it away and/or constantly dirty your fuel. Its a good investment IMO to keep the car alive and trouble free, longer.
I realize finding one is not easy. Did you have one made? If so, do you have a sketch with dimensions?
hey there is a bone yard some 80 miles from me that has some early b wagons in it , brian's salvage 707 642-5408 , brian or rose his wife run and own the yard . here is what i saw there .
Im still using my original one for now (it's a driving project atm) but at some point I plan to either make one myself or have one made. I wish I could help more. There was a thread on here maybe a year back where someone said that they found a company who advertises fuel tanks made specifically for EFI. The whole post was about the guy reading the manufacturers catalog at a a car show which lists one for 1962-1965 wagons. I cant recall the name of the company. They might be able to help.
This might be an option.
Mine had a rust hole on the bottom but was otherwise solid.
Tried a few tricks, nothing worked.
Cut out the rust, bought the parts to plug off a sending unit for efi.
There's a ring inserted on the inside with threaded holes, a plate, gasket (special kind, forget the name) and bolts with o-rings.
All Tanksinc stuff iirc.
Not a drop in over a year.
Old pic, since painted.
