63max wedge
Time to move on with my cars. Parting with my 64 S/W 98% rust free new floor pan, new front window, new back side and front window gasket. H/D rear spring eight right and right reached new Yukon axels bearing 5.13 posi. Rebuilt trans with manual shift 9 inch converter. The engine is a 440 block bore to 4.373 with KB 400 piston 7.06 nascar nos hemi rods nos, the crank is a nos 3.48 Kellogg crank and a moper performance .528 lift cam mechanical new reproduce max wedge oil pan. You can say the short block is blueprinted. 40 + year of engine machining this one is for me. The top end is a 62/62 max wedge head, intake and carb 3447. New reproduce clearer new max fuel line mopar performance aluminum water pump and housing. The brakes are 11x3 front and 11x2.5 rear all re built. New front and rear Monroe shock. The wheel are 15x4.5 American and 15x8.5 rear Lots of patina Will be starting the engine for the 1st time 0n 12/15/19. New year one engine wire harness and new dash wire harness. TTT header and exhaust to the rear end. Lot new parts. Send a email address for more photo $15,000.00
