I might offer 2k if I had my eye on it. Idk what it's worth, to each his own I guess. If you have your heart set on it I could see paying more. As an investment or flip probably not--- without more info/history. It looks like a project for what that's worth.
I dont know if is a polara 500Is that a Polara 500?
What i know is a big block aut tomorrow i will be there on the yard ready to inspect the car. ThanksLooks like a good project if it has big block and 4 speed that would be great. Money is your call how bad do you want it.good luck with it.
Those are the only ones that my friend send me.Impossible to give you a reasonable answer from information/pictures you provided.
Side trim looks like a 330 or 440 trim level...not a PolaraI dont know if is a polara 500
I am not specialist on 64 years.Side trim looks like a 330 or 440 trim level...not a Polara
It is a Polara! 330& 440 models do not have the wide side trim! If you enlarge the pic. you will see the Polara medallion on the 1/4Side trim looks like a 330 or 440 trim level...not a Polara
How can i know if the car is polara or 330,440?
Is the car is good editions does need to be a s code on th second number like the 70's?
Ooo ok thanks bearman that will help me alot.Look at glove box door the emblem in the corner will tell you what model it is. Also if you have trim bars on the trunk lid it's a 500. Also rear tail lights two reds and a back up light in the middle. Hope this helps
