'64 power window lift
Buds 64
7:39 AM
San Antonio TX
Hi guys,
The pass. side power window motor assembly on my vert has a broken gear. Does anyone have a source for parts for this assembly or a source for a replacement?
Alternatively, will a later model motor assembly of the same design work as a replacement? Those seem to be available. My unit has a drive gear (the one that meshes with the sector on the lift mechanism) that is 3/4" in diameter with 9 teeth. I guess that would be the key to a suitable replacement.
Thanks for your help.
Try Wildcat Auto Wrecking in OR 503-668-7786, Rocket Restorations in WA 360-426-0762, Andy Bros. Old Steel 618-978-2413, Marcus in WA 253-906-6980, Joe Suchy in GA 770-964-4441, Terry in MO 816-682-9650 or 913-897-2324.
I'm at least 1 of them can help you.
Good Luck
s5757s
