64 savoy doors
64savoyguy
6:03 PM
sioux city ia
Ok guys heres my question. I needed doors for my 64 plymouth savoy and was able to locate 2 nice ones however they were completely disassembled. I am to the point in the project were i need to put them together and have no clue where to start. I would assume the wing windows go in first but not sure. Right now the windows are separate from the regulators. Do they go in as a unit or onefirst then the other. Any help with this is greatly appreciated. Thanks in advance!
Everybody will do this differently,, I install the wing and front track in the door,then the regulator then the glass with 1 window fussie installed on the inside top of the door.(keep everything loose and wait till all parts are inside before tightening bolts) Next install the outer fussie ,slide the glass up the track about 1/2 way and slide the regulator rollers into the glass track. The Savoy sedan with the window up will square everything and then start tighting the attaching bolts. I see it easier in my head than the explaination that was typed.
