In the back of the 65 Belv instrument cluster circuit board, there are 2 5 pin connections. How do I tell which is pin one and which is pin 5? I want to make sure the harness gets plugged in correctly.
Do you have 65 wiring diagrams, or service manual? If not, MyMopar website has both.
Had to get the 65 manual, since 64 isn't available, for testing parts and pieces.
Traced one wire from the left pin set...goes to the ignition switch. Not much help at the moment.
