64plybelvwgn
Hi,
I have a 65 Belvedere, with a 70 440. It was a "kind of" barn find from an elderly gentlemen ( I gotta a lot of nerve saying that since I'm 70yo myself ! ) and I am trying to straighten out some of the issues that were probably ok 15-20 years ago.
It was converted to power disc / drums with something that looks more GM than Mopar. Because the 440 has a "purple cam " of yet unknown spec, I suspect ( and will be checking ) how much vacuum I'm getting for the booster.
However the proportional valve and plumbing are a nightmare ! I was considering taking the whole setup out and going to a Wilwood manual master cylinder ( 7/8 bore ) which would negate booster vacuum issues ( I rarely if ever see power brakes on 1/4 mile cars and they seem to be able to stop with the Wilwood manual system ) , or using the existing setup, however tear out the plumbing and install a Prop valve just in the rear line and re-route the front line into a line-loc then split to the front discs.
Any and all comments and suggestions would be sincerely appeciated.
Thanks and regards, Ted
