65 Coronet - 440 engine exhaust manifold help
bparrishlvx
New Member
7:51 AM
Las Vegas
My dad has a 65 coronet 500 that he is pulling the original motor and replacing it with a 69 440. My question is......can we run the HP 440 exhaust manifolds or will we run into fitment issues? Also, one more question,.....even though the books say that bellhousing number 2468370 is for 10 1/2" clutch, can I run a 11" flywheel and clutch in that bellhousing? Any help would be great. Thanks
The manifolds will work!You will have toremove the flapper and plug the hole.It will hit the shock tower.The 11" flywheel won't work with 10.5 bellhousing.
