65 Coronet Door Window Seal Question
DART505
10:26 PM
Louisiana
Looking at replacing the outer front door glass seals and replacements show flat type or round type. What gives, how to know what you need ?
Can you send a photo? I am doing a 65 now and can tell you the Steele Products are worth the $
Dan
The outers are the same, the inners are what may vary. The flat bead is a chrome band that lies on top of the window felt at the top of the door frame. The round bead is a small round bead that is attached at the top of the window felt. It is just a decorative trim.
The Top Catwhiskers are the most correct window felts and offers the different variations of these felts.
Hopes that this helps.
Thank you, I will be ordering some from you.
Ordered ! Called in and being made and glad I did. Needed 6 piece set . Thanks
