65 Coronet Sill plate trim piece ?
jimbosride
6:33 PM
Washington state
Hey ... Am I missing a trim piece here around the back seat ? or is this normal ??
65 Coronet 2dr
:thankyou:
yea ... the carpet is a little short . Just wondering if I'm missing some trim?
If there isn’t a trim piece for back there you might try a WTB ad for a set of used plates and cut the rear extension off and mount them behind your existing plates to cover the area.
65 Coronet 2dr
:thankyou:
You made me go out and check my 64 Polara HT,,, maybe they're different than a Coronet? But in 64 they were 1 piece and fit the car properly.
Also, it appears that you possibly have a 4dr seat bottom. Like mine has
Remchargers pics are correct...
Ditto for Quickbpbp's post...
I know several years ago correct ones were repopped...then sold out and were no longer available...
'65 Coronet Sedan survivor:
You guys are right. I sit corrected.
As I posted, I vaguely remembered an extension inner trim that covered that portion of the interior floor rug, but forgot in the midst of creating a super light interior without the rug. Glad some cats here had photos because I thought I was bugging.
Carry on.
My 65 Coronet 2 door hardtop looks like the one @VANDAN posted. Purchased from Layson's. I just needed passenger side. As @QuickBpBp said, they are different on the vert.
ok mine is not that long so I my have the wrong one ? But what does the shorter one I have fit? or is it a bad re-pop design ?
See post 10. If nice someone WILL want it.
If you want to buy the correct ones, there are vendors that sell all 4 - 2 inner and 2 outer. Layson's is the only vendor I found that sells just the inner. If someone needs just the driver side inner, they can have mine.
