65 Satellite neutral safety switch
gto64gto
9:24 AM
Tabor City, N C
I have a 65 Satellite and I need a NSS and wiring harness. I don't have 1. The switch in my transmission had 2 pins when I got it. I know it's the right one and I need to get this fixed for safety reasons. Thanks.
do you have an original cable shift transmission in the car? if so it should have a one treaded stud neutral switch in the trans and the one wire went up to the starter solinoid
This is the correct nss for a 65 console/column cable shift 727, but there is no harness, just a single wire.
You can also drop your pan and check if the rooster comb has two fingers, one for neutral and the other one for park position.
Otherwise it is not a 65 valve body.
http://www.1962to1965mopar.ornocar.com/transtech.html
A 64 push button has a different nss by the way.
Dan
