65 Satellite park/shift cables
easyrider
9:37 AM
North Carolina
I'm having trouble with my park cable. Sometimes, when I put it in park, it still rolls then catches. Is the adjustment hard to do to fix this? Also, I am having a problem with leakage of trans fluid through the cable coating. I know that Schumacher Creative Services sells these cables, but went to their web site and there is no mention of them. Does anyone know the price for these cables? I purchased a speedometer cable from them and it is working perfectly and no leaks. I don't know if anyone else sells these cables, but if price is reasonable will probably buy again from Schumacher. Very good customer service.
I know the cables are expensive some where over $200.00! But no one else has them I know of!used ones are getting hard if not impossible to find good ones! So you just have to bite the bullet some times!
The adjustment is wrong, that is why park doesn't catch. Loosen the pinch bolt near the park housing. Remove the cable and slide a piece of heat shrink (the type that has glue inside) over the cable. Heat it and it will seal the cable. When reinstalling the cable slide it right or left in the housing to adjust. That will take care of your park problem. If you can't find the heat shrink PM me and I'll send you some. Both easy fixes. Mine no longer leaks a drop.
Doug
