They should be the same as 4 speed.wanted the auto brackets
Different. Pretty sure the auto floor shift ties into one.They should be the same as 4 speed.
I will look at my brackets. Might take a few days. Are you looking for correct or functional?Different. Pretty sure the auto floor shift ties into one.
If he intends to use the original factory floor shifter he will need the brackets for an automatic. The shifter mounts to the brackets where the 4 speed does not.I will look at my brackets. Might take a few days. Are you looking for correct or functional?
Thank you.If he intends to use the original factory floor shifter he will need the brackets for an automatic. The shifter mounts to the brackets where the 4 speed does not.
