GassMann
Hey all,
I have read many posts here and can see I am not the only one struggling with this issue. As a primer, I've had this Charger since i was 16 a towed it around everywhere I went since. I rebuilt this 66 from the ground up over the past 7 years. The steering has new upper and lower bushings, tie rod ends, pitman, idler arms and ball joints. I also upgraded the front to disk breaks.
Currently the car has serious camber issues since, of course, EVERYTHING is new and was disassembled and put back together. The cams are not adjusted at all so the tires spay out bad. No... I am not driving it yet.
I have checked around my entire area for an auto shop that will do a front-end alignment on anything older that a 1980 car and I came up short.
I am now looking at alignment kits and some advise from the pros. I have seen these low-cost magnetic camber/caster devices. Are they worth it?
Or should I invest in a professional tool kit like "Quick Alignment Kit"
I mean, I know how to adjust each setting and I know how to use a tape measure. The hard part is always the camber/caster. Setting the toe and centering the steering wheel is (I think) an easy matter of adjusting the linkage. In high school, decades ago, I learned how to align steering so I understand the basics. But, like many things with this car, this will be my first actual alignment. Kind of looking forward to it to be honest.
Sadly, I don't have a ton of cash to put into tools and I hate the thought of tossing hundreds of dollars at a tool set that is overkill or does not get the job done. Like grease plates... are they worth it? I can get 4 sheets of steel and grease them up... but not with degree markings.
Anyway... ANY suggestions you have would be welcomed.
Thanks in advance.
Thanks in advance.
Now you gave me more **** too investigate.
