66 Charger Headlight Hold Open
Hutch9531
5:35 PM
Biloxi, MS
Anyone out there that might have or know someone that has a Headlight Hold Open Switch from 66 or 67 Charger I need one.
Not sure if you are missing yours or not but if your having problems with the switch it can be taken a part to clean the contacts. I have done that with a couple of them and it works great.
Hi,
They are easy to open and clean...also, I think it is the same switch as the emergencey flasher switch.
Regards,
Ken
66 hold open switch is unique to that year, 67 switch is the same as 4 way switch...66 switches can be taken apart & cleaned to work
Bryan
66 Charger Headlight Hold Open Switch
Thank all members for your inpu, I have a switch on the way to me, special thanks to Jim Bob Dancing Bear for providing solid leads.
1966 headlight rotating switch
can that switch be repaired? I broke the wire connector on mine and was just looking for another to replace it.
