Did you check with "gibber" aka the Gauge Doc? He might have a rebuilt gauge ready to go.
Is the gauge not functioning? Or is the EL & pointer not lighting?
If you have cores, oil press gauge rebuild is 95.00. Tach rebuild is 100.00 (if required). Figure 15 dollars shipping...
If your tach isn't working, most likely the tach sending unit is bad. Tach itself it probably just fine. I charge 175.00 to rebuild your sender and calibrate to your tach. I'd need both the tach and the sending unit to see what's up...happy to help!
