66 Outer wheelhouse
Stowe
3:16 AM
NY
Hello, Has anyone ever modified 68-70 outer wheelhouse to work with on a 66? Or any other suggestion on what may fit with some modification?
66/67 and 68-70 are not even close.
66/67 4 door parts car is probably your best bet.
4 door cars don't get rainwater drainage from the back side windows on the wheel house, so they rarely rust.
However, I believe outers are different between Dodge and Plymouth.
What side are you needing? I have a 67 4dr that I'm using as a donor and know I need the passenger side but haven't inspected my two dr drivers side to see I'm going to need it yet.
Passenger side thanks for checking
When you figure out what works, you need to start a parts wanted thread. There's a good chance someone will have what you need. Do you need a whole wheelhouse or just a partial for some rust repair?
Someone just posted complete 67 wheelhouses in the sale forum.
I have a set from a 67 Belvedere ready to cut out the piece you need.
Thanks , I actually had a metal guy make one from I will keep you in mind once i take a look at the other side
