66 Satellite Power Booster Question
Theverza
3:00 AM
US
Hello fellow MOPAR fanatics!
Quick question. I pulled a power booster and master cylinder from a 68 GTX for my 66 Satellite. My Satellite didn't originally come with a power booster and I discovered that the bolts don't quite match up. The master cylinder I got matches just fine though. Is there an adapter out there that will make it fit? Or do I have to drill through the firewall?
Thanks!
-Dave
I converted my 66 over to powerbrakes. If you car didn't come with power brakes then you need to change the firewall plate. The black plate between the booster and the firewall. The hole in the plate is lower with power plates. You could modify you old one if you can't find one but you would need a template. The holes on the firewall are the same from 66-70.
