67 Belvedere parts to 63 Dodge
Black63
3:53 AM
Canada
Hi guys...
A good friend has a 67 Belvedere mordoor that I can have parts from.
The Bel has a 318 (313?) Poly drivetrain that he is gonna use in a Hot Rod...but everything else is mine for the taking.
So, I understand the K frame will fit but what about the V8 torsion bars and the rear springs?
My car has some serious droopage going on...LoL.
What about door hinges and door latches...stuff like that??? Wiper motor?
The car has power steering too and I'm hoping that will bolt to my \6 63 K frame. I can adapt the pump brackets.
Pwr booster worth getting? I'll be doing a disc swap and I hear whispers that the drum booster might not be up to the task.
Sorry about the stupid Newbe questions...but I'm totally new to owning a classic Mopar...and doing a search for each piece of info would eat up an afternoon!
K frame yes. t-bars yes, rear springs have longer front segment on the 67 so no. No on the wiper motor, hinges compare, kits to rebuild yours are cheap and avalible, power steering will bolt to the slant K. Booster will work make sure to take any brakets and push rod that connects to the pedal.
The k-frame will set the engine back.You will have trans mount concerns and maybe header fitment.
Thanks for pulling this up and posting guys!
I figure the Poly T-bars are heavier and will make a good swap into my car to stiffen up the suspension slightly. Too bad about the rear springs though.
I'll see if I can mix and match between the two sets to get an extra couple of leaves into the 63 packs (with proper stagger between each leaf) and have then rearched slightly.
Glad to hear the pwr steering and brake booster are usable.
Looks like I'll be getting it all this weekend.
The 63 is going in the shop before this weekend and I'll be making a small start on it before Christmas.
I'll post a few pics once I start...
