67 Charger 318 car power brake questions
dieseldazzle
9:36 AM
California
Anyone happen to know what size bront and rear brake shoes would have come standard issue on a 1967 charger 318 car with power drum brakes?
It has 26inch radiator due to factory A/C if that matters?
Anyway to tell before pulling the front and rear tires off? Id like to order new shoes and hardware, wheel cylinders etc prior to pulling the car apart.
Thanks guys.
More than likely 10 x 2.5. You need to check drums to see if they need replacement any way would be a good time to check brake size.
yes, 10" x 2.5" all the way around...both my 383 cars are 10" brakes as well, non power brake cars also
Thanks guys. Ill be ordering new drums as well. The power drum brake system is fine for the driving I do in this car and I want to keep the factory rims it has on it.
you might as well order new lug studs for the front drums also...they have to be removed and put in the new drums...might be hard to find stock left hand thread ones though
Thanks my man I forgot about that and one of mine is actually stripped.
