bcOH67
Hello. I am fairly new to the car world and don’t know very much about diagnosing or solving electrical issues. So any help that you can give is greatly appreciated!
I am having an issue with my headlights were they will operate fine two or three times on a fresh battery but then they stop working.
My charging system is testing fine. I have found that I have constant power going to the headlight relays. Is this correct or could I possibly have a faulty switch or wrong wire?Because I think the relay is just overheating and shutting itself off… Do they do that?
There is also a constant click that comes from behind the dash on the left side of the steering wheel....it almost sounds like the turn signal indicator working but a lot slower. The clicks are spaced out about 5 seconds. Sounds like something is getting power then losing power, then getting it and losing it, and so on. Any ideas?
Thanks!
Brian
Thanks!
Brian
