Stonehengeheel
Is there any way to adjust the pedal height so it is nearer to the floor. We installed a new Booster and Master. Thanks.
Thanks. It was 4 wheel manual drum. Put in a generic unit I got from Jegs. I think the rod between the booster and Master Cyl may be too long? Any suggestions would be appreciated.Was this originally a PB car or did you convert it to PB. The revised linkage attachment point for a PB car usually lowers the pedal significantly from manual brake height.
