67 coronet front park lights
krowbar
6:29 PM
979 Texas
I just finished installing New headlights and parking lights. I painted all the headlights buckets and grille. I put the bumper back on. I got the tail lights back in. All the lights and blinkers work. Hazard lights don't come on ( not real worried about that ). I deleted the fender turn signals. Question is.....The front parking lights go off when I pull the headlight switch all the way out to turn on the headlights. Is this normal? Seems odd to me.
That is normal on a 67 B-body. Before you go crazy on fixing the 4 ways, try taking the switch out, take it apart and clean the contacts. Works most of the time.
Yes you do..if you want to do it correctly.
But with a pair of long nose needle pliers you can do it as well. Be careful and make sure you are not rotating the entire assembly. I have done it this way. But this summer I had my dash out a few times so I just bought the correct tool from ebay.
ANd my parking lights go out when the headlights are on too. 67 Corrie 500.
