Stonehengeheel
Do I need to pull the tank to replace the sending unit gasket?
Just try and time it so the gas tank is nearly empty......for if you should drop a near full tank slightly......Do I need to pull the tank to replace the sending unit gasket?
you can do it in place, have a 1/2 tank or less , it's tight but it can be doneI did my sending unit on my 70 satellite without dropping the tank. Pretty easy to do.
