67 Coronet Windshield Install Help
Schober Motorsports
4:30 AM
Drag Strip
Anyone got any advice on this?
I got a new seal and a new windshield and also mixed feelings on installing this windshield. This is the style where you need to force the windshield into the small groove in the seal.
I've done everything else on the car and haven't payed anyone to do anything on it? How hard is it to install? Any tips or tricks that could help out?
Thanks!
Craig
Craig lots of soap and water, do it on a warm day. I use hand cleaner to lube the gasket. A string inserted between the glass and gasket and slide around as you pull the gasket over the window edge helps. Just remember rear glass is really hard to come by. watching some one will help. But at least you need 2 friends to hold the glass in place with Suction cups. I would go to You tube and look for a video of the install.
