Joseph Halstead
- 10:07 AM
- May 25, 2016
First, the drivers door and rear passenger doors appear to be stuck hard. I believe the latch mechanism is still intact as I can definitely feel the door is locked when I lock it and the button does appear to have an unlatch feel to it. Any ideas? I have tried pushing the button hard and banging on the inside of the door but that has not helped.
Second, While trying to get the 318 started I noted I had spark from the ignition coil but it would not fire or even really try. After pulling the distributor cap I noted the position of the rotor and tried to turn the engine over again. The rotor did not move. I am going to assume the distributor gear is destroyed but ever distributor I have found seems to not have the gear. So what am I missing? Also what do I do about the destroyed gear?
