gtxno1
Hi everyone can anyone tell me the correct part number for a 67 GTX 440 auto trans vacuum advance thanks
Good luck with this one. Check for a date stamp on the inside of the distributor, my 67 383 had a '66 date on it and the advance pod Is obsolete ! ended up having to change distributors. If you can snap a picture i'll be happy to let you know if it was the same as mine, I still have it and the dist. on the bench.....
Out of curiosity I checked an old distributor on the shelf, that came off a 383. The vacuum advance part# is 2642774. What would that have come off originally? Or what is it correct for? Thanks "in advance"If I'm reading my parts catalog correctly - Vac Adv for a 440 w/ Auto trans - Hi-Perf is #2642780, and for Std Perf #2642526.
That's with a Hi-Perf distributor number of #2642822 and a Std Perf distributor number of #2642816.
Thanks for the info when I researched the distributor according to the Galen white parts book the distributor should be 2642748 without cap package the number distributor you looked up is for the cap package could you check which vacuum advance goes with this number thanks
