when i turn on my headlights the tach doesn't work, turn off the lights and it works, and when i hit the brakes, the brake lights flicker, what could be the problem?
Sounds like two separate issues. The tach is loosing its ground. When you say brake lights flicker I assume the lights in the rear? If so I susspect a ground issue there also.
