68-70 Charger: Where does Rocker to Door Pillar Brace Go?
RXTREME
3:56 PM
Houston, Texas
Forgot where this one went even tho i planned everything out
IIRC correctly..... it is spot welded to the rear of your B pillar, and it is also spot welded to the top of the rocker panel, behind the inner face panel, ( the semi flat panel ) that the window regular assembly bolts to. I think we have a pair of used 68 charger rocker panels
with the b pillar still on them, and I will get a few pics of that support tomorrow. The outer quarters have been cutoff, and the bracket should be easy to see.
